[SOLVED] DOF: How to exclude Nodes?
Heyho
How can i exclude a Node from DOF? For Example the Sky in a World.
Sky is a Skydome Mesh (ObjectMesh)
Thanks for the help in advance :)
As DOF is a post-processing-effect some masking within DOF fragment shader will be required. Might be possible to use depth texture and use some max z depth to decide if given pixel should be included into DOF blurring (even though I don't understand why to exclude sky from DOF processing as a sharp sky and a DOF blurred scene might look a little bit odd). Other alternative might be to enable auxiliary buffer rendering for specific nodes to initialize mask buffer texture.
maybe this helps more to understand why, ulf:
  • 2 weeks later...
  • 5 weeks later...
Render composite shader will be more configurable. You will be able to exclude arbitrary objects from DOF and Motion Blur post processes.
