[SOLVED] Unigine Script Callbacks from external C++ script
Hi, I've managed to make a plugin that is loaded successfully by the game. Right now, I'm trying to call a function in the world script via the plugin. I can't figure out how to make the sample in the documentation work. I tried inserting the provided code into my plugin script, but it does not seem to load correctly. I suppose it's because main(int argc,char **argv) is not called. I would have attempted to call aforementioned function in the definition of my plugin init but I do not know what parameters to provide. Any help on the matter would be appreciated.
Could you provide your plugin code to us?
I got it to work already. Here is my code:
#include <Unigine.h>
#include <UniginePlugin.h>
#include <UnigineInterpreter.h>
void TestFunction() {
Log::message("This is a test function.\n");
const Variable &runWorld(const char *name,const Variable &v) {
Log::warning("runworld(%s,%s): called\n",name,v.getTypeName());
Engine *engine = Engine::get();
return engine->runWorld(name,v);
class CallbackPlugin : public Plugin {
CallbackPlugin() { }
virtual ~CallbackPlugin() { }
virtual int init();
virtual int shutdown();
virtual void update();
int CallbackPlugin::init()
Unigine::Interpreter::addExternFunction("TestFunction", MakeExternFunction(&TestFunction));
char *string = "this is a string";
char **stringPointer = &string;
int CallbackPlugin::shutdown() {
void CallbackPlugin::update() {
Variable ret = engine->runWorld("counter");
if(ret.getInt() != -1) {
Log::message("counter is: %d\n",ret.getInt());
extern "C" UNIGINE_API void *CreatePlugin() { return new CallbackPlugin(); }
extern "C" UNIGINE_API void ReleasePlugin(void *plugin) { delete static_cast<CallbackPlugin*>(plugin); }
My mistake was in assuming that the code provided in the documentation should be used as is. Thanks.
  • 1 month later...
