[SOLVED] NavigationMesh problem
Hello.
Issue 1
I face a problem considering NavigationMesh and NavigationSector.
First of all, using a Navigation sector i create a box and i use a PathRoute from one point to another (both inside the navigation sector). Everything works fine.
Then i try to replace the navigation sector with navigation mesh. I use a mesh that i create in 3ds max 2012 and has exactly the same length/width/height as the navigation sector. But the route is not rendered.
navigation sector code.
 NavigationSector navigation;
 int navigation_sector_length = 300;
 navigation = add_editor(new NavigationSector(vec3(navigation_sector_length, navigation_sector_length, 9.0f)));
 navigation.setWorldTransform(translate(Vec3(0.0f,0.0f,5.0f)));
navigation mesh code
 NavigationMesh navigation;
 navigation = add_editor(new NavigationMesh("demos/Marina2011/meshes/Navigation/Box260.mesh"));
 navigation.setWorldTransform(translate(Vec3(0.0f, 0.0f, 0.5f)));
I have also noticed a problem in the navigation mesh.
2 lines for each edge are rendered.
I send some files that might be helpful.
Issue 2
I want to create a complex navigation mesh. is 3ds max the only way to do it ?
As i read, meshviewer is used only for preview purposes.
Thank you for your time and sorry for the long post.
Navigation.rar
Hello.
As it seems the problem was that i was using a 3D box instead of 2D plane.
Thank you.
