sergey.shandar Posted June 5, 2012 Posted June 5, 2012 Is there a way to clone a dynamic mesh so it clones all vertices and indexes etc as well? I've tried ObjectMeshDynamic.clone() and node_clone(). It looks like the cloned objects still references on the same vertex and index buffers. :-(
ulf.schroeter Posted June 5, 2012 Posted June 5, 2012 It looks like the cloned objects still references on the same vertex and index buffers. :-( That's right and it does make sense to save GPU buffer resources if identical meshes should just be rendered multiple times e.g. just with different node transformations. If you need "deep" cloning including vertex/index mesh data duplication you can do it via a Unigine script functions ObjectMeshDynamic::get/setVertex/Normal/TexCoord/index()
