[SOLVED] Sprite - Color - Render Problem
Hello together,
I attached an example project.
If you start the batch, you'll see a TabBox, with a given sprite, that loads a white PNG file and renders it with a given color.
If you swap now fast the tab's you'll see, that the color of the sprite swaps to blue/green/yellow and so on, and always render the widget complete from right to left, or left to right whatever, that looks not really "cute" and fine for the consumer. Is there any possibility to manage this problem(s)?
Best regards
Lars
The sprite color should be normalized in 0.0f-1.0f range.
sprite.setColor(vec4(13,100,0,50) / 255.0f);
Hello Frustum,
thanks for that fast reply. That solved this problem :D
Best regards
Lars
