[SOLVED] Possible to add external GUI-Framework
Hello
Is it possible to add, over the plugin system, an other GUI-Framework into the engine?
We have only the Binary-Version of Unigine and no access to the source code.
Thanks and greets
Manuel
Yes, of course, you can write a plugin that renders your custom GUI. But keep in mind there are some C++ API limitations:
1. Rendering of your GUI to a texture and passing it to the engine is not possible.
2. Engine renderer functionality is not accessible via C++ API.
3. Your GUI can be rendered only atop of the screen.
Other than that, all is possible! ;)
  • 5 weeks later...
Hello
The "big" problem with these limitations is that fullscreen will never work.
What would be very,very, very nice is a new widget type which can be accessed from c++ and provides an interface to write into the widget.
Something likes an OpenGL/DirectX overlay on some parts of the application. (where the widget is placed)
I have no idea if it is possible but it would be a nice extension.
-- A question on the edge, is it possible to get complete ActionScript sample?
Thanks
Manuel
Hi Manuel,
It will! There is absolutely no problem with rendering in a full screen mode.
For now we stick to approach when widgets are only created on the script side or loaded from UI files. With a Plugine system though, you can render anything atop of the scene.
You mean an example of a working Flash interface? A Shooter prototype uses Flash-based one.
