UNIGINE 2.22.0.1 hotfix is now available for download! ×
[SOLVED] Finding mesh object issue
I have added few ObjectMesh using add_editor(new ObjectMesh("*.mesh")); after this I set transformation matirx & set material & property for all the mesh objects.
Now I am trying to get access to the names of each of these meshes using ObjectMesh.getName(), but I am getting null values to all.
Can anyone tell me at which stage the names will be assigned to dynamically add objectmesh, so that I can access them after it.
Thanks
Use that way of creating a mesh won't have a name, so of course you'll get null string
But when I check the nodes from the editor, I am able to see the names of the ObjectMesh.
So if I am not able to get the names of the objectmesh through mentioned way, than what is that I need to do to access the specific objectmesh
Thanks
Yes you can see the name of mesh like ObjectMesh_xxx, but if you select it, you will find the name part in Nodes tab are blank. Meas no name, use id if you can or manually set the name.
