making use of windows api
Is it possible to make use of windows API in our project?(like DCB structure) How to set up the compile environment?
Please, compile the project using SCons because we check all of the options for each file and for the included and referenced libraries.
Could you please provide us more details on what are you trying to achieve?
Thank you for answering. And how could UnigineScript get return data(value) from external function of exported user defined class?
You can use Variable type or any build in type (float,int). Please, see the following sample: Samples/Api/Functions/Function.cpp
Variable my_sum(const Variable &v0,const Variable &v1) {
if(v0.getType() == Variable::INT && v1.getType() == Variable::INT) {
	Log::warning("my_sum(%d,%d): called\n",v0.getInt(),v1.getInt());
	return Variable(v0.getInt() + v1.getInt());
if(v0.getType() == Variable::STRING && v1.getType() == Variable::STRING) {
	Log::warning("my_sum(%s,%s): called\n",v0.getString(),v1.getString());
	return Variable((std::string(v0.getString()) + "+" + std::string(v1.getString())).c_str());
Log::warning("my_sum(%s,%s): called\n",v0.getTypeName(),v1.getTypeName());
return Variable("unknown");
