[SOLVED] WorldTransform rotation issues
Hello !
I'm having some trouble using WorldTransform class for a rotation only movement.
My code is :
* Rotates an object around given axis in the given time
* @param[in] o Object to translate
* @param[in] axis Rotation axis
* @param[in] angle Rotation angle
* @param[in] time Time to travel
void RotateObject(Object o, vec3 axis, float angle, float time)
 // Valid time and object ?
 if (o != NULL && time > 0.0f && length(axis) > 0.0f)
  // Declare a world transform
  WorldTransform wtr = node_remove(new WorldTransform()) ;
  // Build a frame in the transform for start point
  int frameId = wtr.addFrame() ;
  wtr.setFrameTransform(frameId, o.getTransform()) ;
  wtr.setFrameTime(frameId, 0) ;
  // Build a new frame for end point
  wtr.setFrameTransform(frameId, o.getTransform() * rotate(axis, angle)) ;
  wtr.setFrameTime(frameId, time) ;
  // Add child to this tranform
  wtr.addChild(o) ;
  // And then play !
  wtr.play() ;
The rotation appears to be done from (0;0;0) coordinates instead of the center of my object.
However, this code :
o.setTransform(o.getTransform() * rotate(axis, angle))
produce the correct behavior (rotate around the object's center not depending on its space position).
Could you please explain what I'm doing wrong ?
Thanks !
That is probably because child transformation.
Lets put your object transform as T_obj and WorldTransform as T_wt. When you add your object as WorldTransform child it will have T_wt * T_obj world transform.
T_wt in your sample is equal to T_obj * rotate(axis,angle), so child world transform will be T_obj * rotate(axis,angle) * T_obj and that is not what you want.
Try to set child transformation to identity matrix. Here I modified your code sample:
  wtr.addChild(o) ;
  o.setTransform(mat4_identity); // NEW!
  // And then play !
  wtr.play() ;
Hope this was not complicated. :)
I understand perfectly :)
In fact, it's my models that are not correctly built under 3DS Max and lead to this incorrect behavior to my eyes.
Thanks for your time !
