[SOLVED] Evaluation Scratch Project Editor Bug
I am getting an error in the scripts for loading the editor. The error I get is this:
set_wave(wave_0_el,water.getWave0());
core/editor/editor_objects_water.h:105: Interpreter::parse_extern_class_begin(): unknown "ObjectWater" class member "getWave0"
Editor::editor_load(): can't load "data/core/editor/editor.cpp" editor script
I have tried commenting out the offending sections of code and it still gives me this error.
Just a guess: There has been an update of ObjectWater wave parameter functions in the latest SDK. Check documentation
ObjectWater and ObjectWaterMesh wave parameters can now be controlled via four simple functions: setWaveAngle(), setWaveSpeed(), setWaveLength(), setWaveHeight().
[/Quote]
It seems that binaries are out of sync, we'll check it tomorrow.
UPD #1
To fix this issue, please copy directories core and scripts from data folder (which is located in the root folder with browser.bat) to scratch/data.
This issue will be fixed in the next update of SDK. Thanks!
Ulf, yeah I figured that was the case. I ended up doing some other things to make it work on my side. This was more of a note for the developers :wacko: And silent, your update worked.
Thank you both for your response!
