Rob Posted September 14, 2012 Posted September 14, 2012 I created a .bat file to start up my world but for some reason it will not work at all I looked at all the .bat files from the other demos but for some reason I cant get it to work This is the error from the log file 10:08:40 RenderPost::get_material(): can't find "render_composite" material It doesnt seem to give any other errors What am I doing wrong?
ivan.cuevas Posted September 14, 2012 Posted September 14, 2012 Check in your log if any of these material libraries is loaded: core/materials/default/unigine_render.mat core/materials/simple/unigine_render.mat Both define render_composite. Check you are calling systemInit() in your unigine.cpp. Check what system script (unigine.cpp) you are referencing in your config file or startup option.
Rob Posted September 14, 2012 Author Posted September 14, 2012 The .cpp wasnt calling anything so thats why it wasnt loading the render_composite I got it working now! Thanks for the quick reply!
