andrey.ershov Posted October 9, 2012 Posted October 9, 2012 PlayerActor actor; Player player; ObjectMesh statue; int init() { actor = new PlayerActor(); actor.setPosition(vec3(0.0f,0.0f,10.0f)); statue = new ObjectMesh("data/samples/common/meshes/statue.mesh"); statue.setMaterial("mesh_base","*"); player = new PlayerSpectator(); player.setPosition(vec3(0.0f,15.0f,10.0f)); player.setDirection(vec3(0.755f,-4.0f,0.25f)); engine.game.setPlayer(player); return 1; } int update() { statue.setWorldTransform(actor.getWorldTransform()); actor.setPosition(actor.getPosition()); return 1; } Нужно еще землю добавить. при выражение actor.setPosition(actor.getPosition()); происходит разворот объекта на 180 градусов. Почему так происходит? о_О We should also add the ground. In marked actor.setPosition (actor.getPosition()); it reverses the object 180 degrees. WTF????? о_О
unclebob Posted March 17, 2014 Posted March 17, 2014 Hello necroposting! I missed you so much. Just to be clear with that topic: any transform changes force Player node to recalculate its inner state (direction, angles and all that stuff). So, for example, direction will be 'negative forward' like in this code: direction = normalize(vec3(-getWorldTransform().getColumn3(2))); After that, in flush, transform will be recalculated from direction so here goes the flip. To solve that use both setPosition and setViewDirection functions. vec3 old_viewdir = actor.getViewDirection(); actor.setPosition(actor.getPosition()); actor.setViewDirection(old_viewdir);
