andrzej.piatek Posted October 12, 2012 Posted October 12, 2012 Run joystick_00 from samples. If you had previously loaded editor you should get ConstrolJoystick::updateEvents(): Acquire():failed. If you unload the editor all will back to normal if you have focus on that window. When you lose focus you will get Acquire failed but according to Dxinput its normal. Focus to ungine window, load editor (console command editor_load) again - everything is fine for now. Focus to other window and next focus back to unigine window - now it wont work. If you click for example in Materials button it will work until you close material window. As far as i can see the problem is focus on main window.
manguste Posted October 22, 2012 Posted October 22, 2012 Ok, we've reproduced this bug. Our devs will look into this issue.
