steve3d Posted November 10, 2010 Posted November 10, 2010 I have read the manual, but seems the manual did not say anything about how to create a joint, for example how can I create a hinge joint. I've tried to set the same parameter with the sample joint scenes, but nothing happend. what does these buttons do? bind, fix0, fix1 fix01? object's local coordinate should be a matter, but how should I set the local coordinate for a hinge joint?
steve3d Posted November 10, 2010 Author Posted November 10, 2010 well, more detail, how to create this joints? my step for creating the hinge joint: 1.create body(dummy) for the base object (black) 2.create a box shape for base object. 3.create body(rigid) for the middle slider object 4.create a cylinder shape for the slider object, 5.disable the shape, then reset the position to it's correct position. 6.add joint on slider object, then select the base object to joint. 7. the slider object disappear. always rendered as invisible wireframe object. if I use a dummy body for the slider object, nothing will happen.
Guest extaliones Posted November 11, 2010 Posted November 11, 2010 Please,upload the test scene without any references to folders on your PC.
steve3d Posted November 12, 2010 Author Posted November 12, 2010 here, the complete scene of this machine. I just want to know how to create those joints. seems the manual described the concept, but no how. 14Mech.rar
