Bug in function addMeshSurface
Hi, i found interest bug when i merge skinend mesh to one surface via function addMeshSurface on ObjectMeshSkinned class.
When i merge skinend mesh in update() function, after when i add second skinned mesh, i get this:
Under horse is person after merge to one surface, next of it is same skinned mesh that i export from Editor and add as skinned mesh to the scene.
Can you check it or anyone know why this happen?
Function for merge it is:
void addToOneSurface(ObjectMeshSkinned equiped[], ObjectMeshSkinned newBody) {
 // ignore main body
 forloop(int j = 1; equiped.size()) {
  ObjectMeshSkinned mesh = equiped.get(j);
  forloop(int i = 0; mesh.getNumSurfaces()) {
newBody.addMeshSurface(0, mesh, i);
mesh.setEnabled(0, i);
If you will want whole scene, tell me, i add it on the ftp.
Thanks for reply.
Honya,
Can you please send us whole test scene?
Hi Necris,
i send you link with more description as messages here.
Thanks, Honya
We've passed this information to our developers.
Honya,
We need a MINIMAL scene -- a case for clear reproduction.
In the scene you've provided there are a number of bones that cannot be found, nodes cannot be deleted by the editor... As much as we would like to help, finding the culprit in it is a bit of a hard task.
Manguse,
That interesting that you get errors with bones.
Dont inteference old smesh with this test scene that we send to you before 2-3 mounts (that have different bones name), because i check smesh that send to you and there have right bones name.
And i send you whole pack, because each combination do some different issues.
Well, the problem is both showcase and showcase_1 are constantly crashing. So there's no way we can check for a bug under these conditions.
Manguste,
ok i now get where it crashing, so i clean scripts from unnecessary code and send it to you via messages tonight.
Meanwhile when you change combo box in "Equip/Unequip animated armors on the character" panel, this panel should not lead to a crash.
Nope, still crashes, still nodes are not removed correctly. Cannot reproduce anything.
Manguste,
messages that node are not removed correctly i getting, but i don't get crash on it...
so what now?
Do you have any idea how resolve this?
Manguste,
i can finally reproduce your crash, so i can fix it and create new scene for you.
When i finish it, i will send you link for download it.
Honya,
Scene still crashes :(
There will be an optimal solution if you send us MINIMAL test-scene. Very simple scene based on update() function which allows to reproduce this issue clearly and nothing else.
One surface and 3-5 meshes for merging on it, without unnecessary materials, models etc.
