eugene.litvinov Posted November 11, 2010 Posted November 11, 2010 Hello. I try to use ControlSetupWindow (InputSystem topic from manual), but when I include import #include <scripts/input/control_setup_window.h> in empty world project I get error: void show(Control control_) { scripts/input/control_setup_window.h:294: Interpreter::parse_function_prototype(): unknown type of argument "Control" in "show" function Is it bug, or I need to include some additional files? test.cpp: #include <scripts/input/control_setup_window.h> int init() { engine.game.setPlayer(new PlayerSpectator()); return 1; } int shutdown() { return 1; } int update() { return 1; } 1
ulf.schroeter Posted November 11, 2010 Posted November 11, 2010 Is it bug, or I need to include some additional files? Add #include <scripts/input/control.h> as class Control is defined there 1
eugene.litvinov Posted November 11, 2010 Author Posted November 11, 2010 Ok, thanks, it's works... another question the same type :) In network demos some variables have type auto, so when I try to launch shooter demo, I get this error: 12:37:36 Unigine~# world_load network/shooter/shooter_world 12:37:39 else cur_size++; 12:37:39 network/common/circular_buffer.h:109: Interpreter::parse_function_prototype(): unknown type of argument "auto" in "append" function what I need to do to avoid this problem? Thanks. 1
Guest anet Posted November 11, 2010 Posted November 11, 2010 Ok, thanks, it's works... another question the same type :) In network demos some variables have type auto, so when I try to launch shooter demo, I get this error: 12:37:36 Unigine~# world_load network/shooter/shooter_world 12:37:39 else cur_size++; 12:37:39 network/common/circular_buffer.h:109: Interpreter::parse_function_prototype(): unknown type of argument "auto" in "append" function what I need to do to avoid this problem? Thanks. "auto" type was removed in last update. But network samples were not fixed. Sorry about that. Just replace all "auto" occurrences with "int". 1
eugene.litvinov Posted November 11, 2010 Author Posted November 11, 2010 Ok, done. Now I get new problem: 14:08:37 Unigine~# world_load network/shooter/shooter_world 14:08:38 PlayerInfo(NetworkAddress a,string n) { 14:08:38 network/shooter/scripts/session_manager.h:42: Interpreter::parse_function_prototype(): unknown type of argument "NetworkAddress" in "__PlayerInfo__" function 1
Guest anet Posted November 11, 2010 Posted November 11, 2010 Ok, done. Now I get new problem: 14:08:37 Unigine~# world_load network/shooter/shooter_world 14:08:38 PlayerInfo(NetworkAddress a,string n) { 14:08:38 network/shooter/scripts/session_manager.h:42: Interpreter::parse_function_prototype(): unknown type of argument "NetworkAddress" in "__PlayerInfo__" function To enable networking functionality you need to use the following option while launching Unigine application: -extern_plugin Network See this post for reference and chat launchers for example of usage Also shooter uses it's own system script and game configuration file that should be specified at startup too. Here is an example of command I use to run shooter: main_x86d -console_command "world_load network/shooter/shooter_menu" -system_script network/shooter/shooter_system.cpp -data_path ../ \ -engine_config ../data/unigine.cfg -engine_log log_server.htm -game_config network/shooter/config/shooter_dedicated_server.cfg \ -disable_start_menu 1 -extern_plugin Network We'll add launchers for network samples in the next SDK update. 1
