a.andreev Posted January 22, 2013 Posted January 22, 2013 Hello! I have a problem with received rail joint from scene in editor. I can get it but is possible to use only basic Joint class functions but no JointRail. Example: //globals Node Wheelset[]; Node Rail[]; Body Wset_body[]; Body Rail_body[]; Joint Rail_joint[]; int init() { int index_of_wheelset = engine.editor.findNode ("wheelset_0"); Wheelset[0] = engine.editor.getNode (index_of_wheelset); int index_of_rail = engine.editor.findNode ("rail_0"); Rail[0] = engine.editor.getNode (index_of_rail); Wset_body[0] = Wheelset[0].getObjectBody(); Rail_body[0] = Rail[0].getObjectBody(); int index_of_joint = Wset_body[0].findJoint("railjoint of wheelset_0 # 0"); Rail_joint[0] = Wset_body[0].getJoint(index_of_joint); Rail_joint[0].setEnabled(0); //That's ok, this method belongs to basic Joint class. ////Another call Rail_joint[0].setLinearVelocity(100); //That's not ok! It seems system not define this joint like JointRail but in scene it's created like this. If I evidently set it like JointRail in global variables - no one methods //works. Editor shows a message: "can't find "class JointRail * __ptr64"... return 1; } How I can achieve my aim, get a joint rail from scene and freely control it? Thank's :)
manguste Posted January 23, 2013 Posted January 23, 2013 Of course it does not work since Body::getJoint() returns a basic Joint instance. And you try to call a method of JointRail. So what you need to do is simply cast Joint to JointRail. Rail_joint[0] = Wset_body[0].getJoint(index_of_joint); JointRail joint_rail = body_cast(Rail_joint[0]); // cast Joint to JointRail joint_rail.setLinearVelocity(100); Just a comment, if you didn't notice that (but I'm sure you did!): Node Wheelset[]; // this is a map Node Rail[0]; // this is a vector
a.andreev Posted January 24, 2013 Author Posted January 24, 2013 Thank you very much! It's very helpful :)
