nat.harrold Posted February 4, 2013 Posted February 4, 2013 Hi Again, Minor bug (but still annoying), "Move Node up in the List" button misbehaves. When having a node selected that you want to move up the tree, clicking the "move node up list" button multiple times can result in your oriiginal selection changing to a random object and moving that instead. This happens if you click the "move node up list" button faster than the node can regenerate its list position. Thanks, Nat.
necris Posted February 4, 2013 Posted February 4, 2013 Issue was reproduced and passed to developers. Thanks!
frustum Posted August 24, 2013 Posted August 24, 2013 Please apply this patch to data/core/editor/editor_nodes.h file at 1430 line: // select node again properly - reselect_node(); + nodes_tb.setCallbackEnabled(GUI_CHANGED,0); + foreachkey(int id; current_nodes) { + if(current_nodes[id] == node) { + nodes_tb.setItemSelected(id,1); + nodes_tb.showItem(id); + } else { + nodes_tb.setItemSelected(id,0); + } + } + nodes_tb.setCallbackEnabled(GUI_CHANGED,1);
