[SOLVED] Swop Chain failed Error
Dear Unigine,
i am testing with the unigine evaluation kit for some while and in various versions.
I downloaded the latest ev.Kit today.
When trying to start the FBX plugin demo, i recieve this message (please see image attached)
This error does not occur always at a specific moment, sometimes when loading the plugin.
The unigine window closes after pressing ok.
Thank you for advise.
Werner
First of all you should also provide log.html file from within your <sdk-root>/bin subdirectory. Also information about your HW, OS, GPU, DX9/11 etc is required. The error message indicates some DX9/DX11 graphics initialization problems which is quite rare. maybe there are some version conflict with previous evaluation kits.
Hello Ulf,
thank you for this information. This already is a good hint.
Yes, I will do that if the error occurs again.
***** Edit ***
The error seems to be consitently popping, while opening a new window.
CPU: Intel I7 960 @ 3.2 GHZ
GPU: Nvidia GTX 680, 4 GB Vram, Gigabite
OS: WIndos 7, 64 bit english
DX: DX 11
Driver: Nvidia driver version 310.90
Unigine log file
14:09:37 Loading "C:/Unigine evaluation/bin/../data/unigine.cfg"...
14:09:37 Loading "Interface_x64.dll"...
14:09:37 EnginePlugins::addPlugin(): "" plugin is already loaded
14:09:37 Loading "dxgi.dll"...
14:09:37 Loading "openal32.dll"...
14:09:37 Set 1280x720 windowed video mode
14:09:37 Set 1.00 gamma value
14:09:37 Unigine engine http://unigine.com/
14:09:37 Binary: Windows 64bit Visual C++ 1600 Release Feb 11 2013
14:09:37 Features: OpenGL Direct3D9 Direct3D11 OpenAL XAudio2 XPad360 Joystick Flash Editor
14:09:37 App path: C:/Unigine evaluation/bin/
14:09:37 Data path: C:/Unigine evaluation/data/
14:09:37 Save path: C:/Unigine evaluation/bin/
14:09:37
14:09:37 ---- System ----
14:09:37 System: Windows 7 (build 7601, Service Pack 1) 64bit
14:09:37 CPU: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz 3204MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT x4
14:09:37 GPU: NVIDIA GeForce GTX 680 9.18.13.1090 x1
14:09:37 System memory: 20471 MB
14:09:37 Video memory: 4095 MB
14:09:37 Sync threads: 3
14:09:37 Async threads: 4
14:09:37
14:09:37 ---- MathLib ----
14:09:37 Set SSE2 simd processor
14:09:37
14:09:37 ---- Sound ----
14:09:37 Renderer: OpenAL Soft
14:09:37 OpenAL vendor: OpenAL Community
14:09:37 OpenAL renderer: OpenAL Soft
14:09:37 OpenAL version: 1.1 ALSOFT 1.14
14:09:37 Found AL_EXT_LINEAR_DISTANCE
14:09:37 Found AL_EXT_OFFSET
14:09:37 Found ALC_EXT_EFX
14:09:37 Found EFX Filter
14:09:37 Found EFX Reverb
14:09:37 Found EAX Reverb
14:09:37 Found QUAD16 format
14:09:37 Found 51CHN16 format
14:09:37 Found 61CHN16 format
14:09:37 Found 71CHN16 format
14:09:37 Maximum sources: 256
14:09:37 Maximum effect slots: 4
14:09:37 Maximum auxiliary sends: 2
14:09:37
14:09:37 ---- Render ----
14:09:37 Renderer: NVIDIA NV70 (Kepler) 4095MB
14:09:37 Direct3D11 desc: NVIDIA GeForce GTX 680
14:09:37 Found feature level 11.0
14:09:37 Found compute shader 11.0
14:09:37 Maximum texture size: 16384
14:09:37 Maximum texture units: 16
14:09:37 Maximum texture renders: 8
14:09:37
14:09:37 ---- Physics ----
14:09:37 Physics: Multi-threaded
14:09:37
14:09:37 ---- PathFind ----
14:09:37 PathFind: Multi-threaded
14:09:37
14:09:37 ---- Interpreter ----
14:09:37 Version: 2.52
14:09:37
14:09:37 Unigine~# render_anisotropy 2 && render_shaders 2 && editor_load && render_restart
14:09:37 Loading "core/unigine.cpp" 6ms
14:09:37 Loading "core/locale/unigine.en" dictionary
14:09:37 Loading "core/materials/default/unigine_post.mat" 23 materials 50 shaders 2ms
14:09:37 Loading "core/materials/default/unigine_render.mat" 47 materials 2368 shaders 8ms
14:09:37 Loading "core/materials/default/unigine_mesh.mat" 5 materials 3386 shaders 12ms
14:09:37 Loading "core/materials/default/unigine_mesh_lut.mat" 2 materials 1062 shaders 2ms
14:09:37 Loading "core/materials/default/unigine_mesh_paint.mat" 2 materials 1158 shaders 3ms
14:09:37 Loading "core/materials/default/unigine_mesh_tessellation.mat" 5 materials 3332 shaders 10ms
14:09:37 Loading "core/materials/default/unigine_mesh_tessellation_paint.mat" 2 materials 2276 shaders 6ms
14:09:37 Loading "core/materials/default/unigine_mesh_triplanar.mat" 1 material 112 shaders 1ms
14:09:37 Loading "core/materials/default/unigine_mesh_overlap.mat" 1 material 300 shaders 2ms
14:09:37 Loading "core/materials/default/unigine_mesh_terrain.mat" 1 material 813 shaders 3ms
14:09:37 Loading "core/materials/default/unigine_mesh_layer.mat" 1 material 84 shaders 1ms
14:09:37 Loading "core/materials/default/unigine_mesh_noise.mat" 1 material 106 shaders 2ms
14:09:37 Loading "core/materials/default/unigine_mesh_stem.mat" 2 materials 2180 shaders 7ms
14:09:37 Loading "core/materials/default/unigine_mesh_wire.mat" 1 material 45 shaders 0ms
14:09:37 Loading "core/materials/default/unigine_terrain.mat" 1 material 1980 shaders 5ms
14:09:37 Loading "core/materials/default/unigine_grass.mat" 2 materials 474 shaders 2ms
14:09:37 Loading "core/materials/default/unigine_particles.mat" 1 material 109 shaders 1ms
14:09:37 Loading "core/materials/default/unigine_billboard.mat" 1 material 51 shaders 1ms
14:09:37 Loading "core/materials/default/unigine_billboards.mat" 2 materials 840 shaders 3ms
14:09:37 Loading "core/materials/default/unigine_volume.mat" 6 materials 53 shaders 3ms
14:09:37 Loading "core/materials/default/unigine_gui.mat" 1 material 82 shaders 0ms
14:09:37 Loading "core/materials/default/unigine_water.mat" 1 material 533 shaders 4ms
14:09:37 Loading "core/materials/default/unigine_sky.mat" 1 material 21 shaders 4ms
14:09:37 Loading "core/materials/default/unigine_decal.mat" 1 material 99 shaders 1ms
14:09:37 Loading "core/properties/unigine.prop" 2 properties 0ms
14:09:37 Unigine~# editor_load
14:09:38 Loading "core/editor/editor.cpp" 302ms
14:09:38
14:09:38 ---- Editor ----
14:09:38 Version: 0.69
14:09:38
14:09:38 Editor::editor_load(): editor is already loaded
14:09:41 InterfaceWindow::create_context(): CreateSwapChain(): failed
14:09:46 Shutdown
Thank you.
Werner
Hello silent,
I installed the latest driver, now the error does not occur so far.
Interesting enough, that it is manufacturer dependent. (gigabyte).
I didnt oc my card.
Thank you!
++++++++ edit: unfortunately, the error came back.
If its the card, its ok, then I definitely need to change it.
(I dont like gigabyte anyway ;))
I will observe this behavior further on.
Cheers.
Werner
Hello again.
I was running a dual monitor setup as those errors occured.
I am running my system on a single display right now, and so far no chain swop error occured.
Will observe it further.
Cheers
Werner
Hello again,
I followed up the problem and I think I found a case, where it did not occur.
It definitely occured on a single as well as on a multimonitor setup.
The error did not occur, as I keep all the new gui windows over the actual scene window.
I ran the editor maximized, so all the menues popped up on top and I did not pull them off the window.
That worked fine for me all day long.
Cheers
Werner
I can cofirm this now.
Working for some days without getting this error.
cheers.
werner
  • 4 weeks later...
I had the same error occuring after installing the latest eval. kit.
I blame it on the FXAA, which I turned on (which also confused me about the text rendering).
Error didnt occur after I turned off FXAA.
B.w.
  • 1 month later...
Running with FXAA turned ON still crashes Unigine with the mentioned Swop Chain Error, on my machine!
b.w.
Np. probably it is the model of the GFX card as already mentioned.
Just wanted to report, that this is still an issue here on my machine.
Will trace it.
Best.
W.
