[SOLVED] Tracker not clean switching ObjectParticles
Tracker enable/disable function doesn't cleanly enable or disable ObjectParticles with Periods/Durations
I even tried with putting my ObjectParticles in a DummyNode and enable that -> same result
Rebuild scenario:
- Take SFX Explosion (one of them) from the library
- Add them disabled to the tracker and enable them somewhere in the tracker
Explosion will reset every tracker frame where it should be "enabled"
Cheers
  • 2 years later...
Solved, the fix will be included in the next SDK update.
