Crash Occluder::clear()
Hi, i m porting an old game make with Unigine two year ago, on iOS, but with the new SDK i have  a trouble when the engine start with crash in the Occluder.
Exactly the problem is inside the clear function i put log file inside the for loop
void Occluder::clear() {
for(int i = 0; i < NUM_PLANES; i++) {
        Log::message("Occluder clear : %d\n",i);
        planes = vec4_zero;
tplanes = vec4_zero;
modelviewprojection = mat4_identity;
tmodelviewprojection = mat4_identity;
has_occluders = 0;
need_clear = 1;
and i take a picture of the crash, i m using and iPad 1 and the neon mat lib.
Thanks
oki it's no so easy to extract just some part but i do some other test and if after some hour if i not found way i try to make you a little sample
Oki, i found something, apparently when i build unigine and my sample only with clang com.apple.compilers.llvm.clang.1_0, i have this error.
If i build Unigine and my sample with com.apple.compilers.llvmgcc42 the problem disappear. Just one more thing, i build unigine without use_memory.
I think there are some trouble with pure clang, because i will have some instability with our Editor and Qt when Unigine was builded with clang.
Silent, do you need a sample anyway ???
Hi Andrey, i put on my server a minimal sample, it's a complete project xcode with two static lib and one ios application,
libunigine.a
libiosapp.a
Sample.app
I don't put the sources of Unigine, you need to add the last sdk in the folder with the same name, theorically the xcode project could be work directly just with plug you iDevice and generate the Sample.app all element will be build and you will see the crash. The exact problem is here :
INLINE vec4 &operator=(const vec4 &v) {
#if defined(USE_SSE) || defined(USE_ALTIVEC) || defined(USE_NEON)
vec = v.vec; Thread 1 : EXC_BAD_ACCESS (code=EXC_ARM_DA_ALIGN, address=0x77dffe8)
#else
x = v.x; y = v.y; z = v.z; w = v.w;
#endif
return *this;
The url of the project : http://test-player.actisku.com/tests/debug/Sample.zip
If you have some trouble ask me  ^_^
USE_MEMORY increase the memory, on iPad1 and 3GS it´s critical for the memory.
It's necessary to use this macro ???
All memory allocations must be 16-byte aligned.
Unfortunately same with use_memory i have the crash.
I add this line for be sure i build Unigine with the macro.
#ifdef USE_MEMORY
    features += "Memory ";
#endif
Inside the console log :
Features: OpenGLES OpenAL Joystick Memory
  • 3 weeks later...
Surprising...<br />Unfortunately we bricked our test iPad1 so we can't test builds.<br />
