[SOLVED] calling class instance function from UI
I have this situation
class X
  void foo()
X xinst=new X();
and ui file with
<callback type="clicked">xinst.foo</callback>
But, i get the can't find callback function error. Any help? Thanks.
Not sure, but you cannot call class instance functions directly, only static functions. Have a look into UNIGINE editor script code in <sdk-root>/data/core/editor, there should be plenty of examples for your use case.
David,
Please check sample/widgets/ui_00 to see how to call class method and pass an instance.
Thank you. Solved. It's not pretty, but works fine.
