ivan.cuevas Posted April 2, 2013 Posted April 2, 2013 With latest Unigine version (2013-03-26) Reproduction Steps Create a Dummy node in editor Assign node_base property to the node. Disable Intersection parameter for that node property. Press Ok. Put focus on Property edit widget again and press enter. Open Assigned property editor, the property parameters are set to their original values (Intersection is checked again) If you don't change the property, there is no point to make a property reassignation removing all the custom parameter values for that node. Suggested solution In editor_nodes.h (ln 845) /* */ void property_pressed() { State s = new State(); if(property_el.getText() != "") { Property property = node.getProperty(); #ifdef OLD_WAY if(property == NULL) s.init_modify(nodes,node); else if(property.getName() != property_el.getText()) s.init_modify(nodes,node); node.setProperty(property_el.getText()); property = node.getProperty(); #else /* OLD_WAY */ if(property == NULL) { s.init_modify(nodes,node); } else if(property.getName() != property_el.getText()) { s.init_modify(nodes,node); node.setProperty(property_el.getText()); property = node.getProperty(); } #endif /* OLD_WAY */ if(property == NULL) { //... } else { //... } } else { //... } //... } For materials, it behaves in this way, you can customize surface material parameters, and if you try to assign the same material, nothing is done, respecting custom values.
silent Posted April 3, 2013 Posted April 3, 2013 Thanks! Information is passed to the developers. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
frustum Posted August 24, 2013 Posted August 24, 2013 Thanks. But I think the patch must be: if(property == NULL || property.getName() != property_el.getText()) { s.init_modify(nodes,node); node.setProperty(property_el.getText()); property = node.getProperty(); } And the same stuff for property_load_clicked() callback is also required.
