[SOLVED] Decal Terrain Base Material, Detail 1 NM not tiling
it seems, that the Normal Map on detail Layer 1 on a Decal_Terrain_Base material does not tile.
The Diffuse texture is tiling, but the normal map is not.
See attached image.
Best.
W.
Make shure that your normalmap texture isn't used in other Decals. Texture can be loaded with wrap clamp option in other material.
Shouldn't the wrap mode, filtering,etc be definable per material instance ?
Ok.
So I need a seperate Texture for wrapping/clamping.
Will try.
thx.
