[SOLVED] Getting started w/ Unigine
I am new to Unigine and have been trying to build/run the Unigine sample Apps on Windows.
I am kind of disappointed that there isn't a single .sln file for all the sample Apps.  Furthermore, when I try to run a couple of apps that I had built (namely, Nodes, States, Objects), I run into the following errors:
. The executable can't find the files under data/core (e.g. fonts and png images).  Is there an environment variable that I need to set in advance?  I also read that all projects need to be built under the 'data' folder.  Do I need to first copy the samples to that folder?
. It cannot find the unigine.cfg configuration file.  It looks under the current directory but no one was provided.  Is there a default 'unigine.cfg' that I could use?
. Some sample apps seem to require OpenAL but nowhere in the documentation I found instructioins on how to configure OpenAL to use with Unigine.  Any pointers?
Also, when compiling one of the samples, compilation failed to find SDL/SDL.h.  There is no SDL.h under the Unigine folder.
Any and all help will be appreciated.
Thanks,
Paulo
Also,
Getting the following messages when building the Objects sample:
Interpreter::load(): can't open "C:/UnigineSDK/source/samples/Api/Objects/data/u
nigine.cache" file
Engine::init(): can't load "core/unigine.cpp" system script
Shutdown
Thanks for the help.
Paulo
If I borrow a unigine.cfg config file from another sample, I get:
Loading "C:/UnigineSDK/source/samples/Api/Objects/unigine.cfg"...
Unigine fatal error
Engine::init(): can't initialize filesystem
Shutdown
Press any key to continue . . .
Any ideas?  Do I have a bad installation?
Thanks,
Paulo
Trying to build the debug version of the Unigine app (to see if I could debug into it) did not work.  I get:
C:\UnigineSDK>cd utils
C:\UnigineSDK\utils>build.py --component=engine --type=debug --bits=64
[ Engine: debug build, 64 bit]
        building main app...
executing command: scons_x64 dev=0 debug=1 jobs=0 -Q -u .
Can't find SCons.
        building Network plugin...
Can't find SCons.
        cleaning sources, keeping binaries...
executing command: C:\UnigineSDK\source/clean.py --quiet --keep_bin 1>nul 2>&1
command failed, return code: 1
Same when trying with scons:
C:\UnigineSDK>cd source
C:\UnigineSDK\source>cd app
C:\UnigineSDK\source\app>cd main
C:\UnigineSDK\source\app\main>scons_x64 double=1
Can't find SCons.
Use *.py files to run samples.
You can use makefile to compile samples:
make_x64 -f Makefile.win32
Ok, looking at the Python script, I am now using the following as command line parameters to run from DevStudio.
-data_path ../../../../ -engine_config ../data/unigine.cfg
This works, thanks.
If I try to build all samples with the Makefile, I get:
C:\UnigineSDK\source\samples>make_x64 -f Makefile.win32
Setting environment for using Microsoft Visual Studio 2008 Beta2 x64 cross tools.
Setting Unigine environment for Windows x64 platform.
Microsoft ® Program Maintenance Utility Version 9.00.30729.01
Copyright © Microsoft Corporation.  All rights reserved.
Makefile.win32(28) : fatal error U1083: target macro '_(TARGET)' expands to nothing
Stop.
Thanks for all your help.
Paulo
  • 3 weeks later...
Still can't run the samples.
Can somebody from Unigine please post the command line parameters for say the Objects sample.
I am using:
-video_app direct3d11 -data_path ../../../../ -engine_config unigine.cfg -console_command "world_load objects"
and I get:
Loading "core/properties/unigine.prop" 2 properties 0ms
Unigine~# editor_load
Parser::load(): can't open "Unigine.h" file
Parser::preprocessor(): can't include "Unigine.h" file
Parser::preprocessor(): can't load "objects.cpp" file
Interpreter::load(): can't open "objects.cpp" file
Loading "core/editor/editor.cpp" 1347ms
Thanks,
Paulo
  • 2 weeks later...
Hi Paulo,
To launch Objects demo, please make sure that <SDK>/lib folder is exists in your system variable 'PATH'.
After that you can run Objects demo via simple console command (or you can make *.bat file):
  • Objects -data_path ../../../../ -engine_config ../data/unigine.cfg -system_script ../data/unigine.cpp -console_command "world_load data/objects"
