Default Texture Orientation
Does UNIGINE assume texture origin at upper left image corner with y going "downward" as depicted in the image view ?
I just got a little bit confused when applying diffuse texture to ObjectTerrain due to flipped y-orientation of the object applied texture (compared to its orientation in image view or image editor programm).
Same issue also arises for other object like WorldClutter, WorldOccluderTerrain or ObjectGrass where mask textures have to be y-flipped before object usage to achive same layout as during texture editing due to "lower left" object origin with y going "upward".
Is this the intended way ?
Terrain heightmap and textures are flipped by Y axis. ObjectGrass, WorldClutter, WorldOccluderTerrain are flipped in same way also.
We should add this "features" into the documentation.
yep, maybe it would even more be helpful if you would add coord axis visualizer to image dialog like the "faked" one in the screenshot. I think this would clarify the default texture orientation/implications. A checkbox for y-flipped image presentation in the image dialog might be also usefull
  • 6 months later...
There is still no ability to flip the Terrain/Diffuse/import. This means we still need to manually flip potentially very large images in photoshop.
Is there a reason that textures are mapped as if they are being projected from underneath, eg mirrored to what is shown in the diffuse preview window.
Can we get an option to flip the diffuse also as Ulf suggested.
Thanks
  • 5 weeks later...
Thanks
Bump up!
We want the "Flip Y axis" option for importing diffuse textures too. Please add it as soon as possible!
Also, if all texture should be Flipped Y when importing, maybe such flipping should be default or even hidden-and-enabled option?
This feauture will be implemented but only in the next update rather than the upcoming one.
