3dsMax -_>Unigine Exporter, Frame numbers to be stored in file
When exporting from different scenes, the exporter does not store the settings with the file.
(I am not sure if this applies to all the settings, but at least I experienced it wit the frame range)
This would be very useful . e.g. when having multiple scenes with different animation frames to be exported, to be remembered by the exporter.
Otherwise we have to type in the Frame ranges over and over again.
cheers
Werner
Hello!
Yes, we also encountered these shortcomings and now searching for possible solutions.
I suppose that this can be resolved if export plugin will use fileProperties instead of having only common settings stored in UnigineExport.ini file.
That sounds good.
We will have to export quite a bunch of animations, and this would help save time.
Cheers.
Werner
