[SOLVED]Update takes 5kms in profiler.
Today I try to export a room model with several furnitures from max to a node.
When i reference the node in the a empty world and look around, i noticed that the fps drops unusually fast when i look at some direction.
If i look at the whole mesh from distance , fps could be 40 or more. So I open the profiler and the update process take more than 5kms sometimes when fps drop. Other processes looks all good.
I looked at the document, it says update is the total time ofworld update script and the number of objects,particles.
But i have only a empty level so the world script should be fine. Also i have no particles and around 1000 objects in the level.
It looks maybe some mesh is not optimized, but I already checked the "optimize vertex" option when export.
Anyone met similar issue before? any suggestion to dig this out?
thanks
Yang
I attach an image which show a different model but have the same issue.
there are a 187 meshes in the level.  the update now drop dramatically when look at some part of the mesh and freeze at last.
it's is a block issue for me, hope someone could help.
thanks
Yang
your model is most probably simply far too complex ( 5 million triangles, 600+ surfaces, 700+ mb textures). Do you have surface LOD's so some heavy-weight surfaces are automatically deactivate in the distance (as an explanation for the fact that the model shows good performance in the distance) ? Could you provide a screenshot with performance data for that case to see the differences ?
Also in the past we encountered some update performance drops caused by collision detection when models were more complex. You could check this guessing by deactivating collision testing on ALL model surfaces.
hi Ulf:
   thanks for you feedback. I attached the distance view. The update only take 1ms. I also tried to disable collider, but not help.
   Only thing i noticed from the profiler when look closer is that "Allocation" change from 3 to more than 1000.
Yang
Strange Indeed. Interesting problem. Unfortunately nothing to add. Thinking..
Hi Yang & Ulf,
I loaded up one of our big ones, to mimic the kind of high poly, high texture memory worlds. I thought I had seen these spikes in update before... see attached. A drop in present, spike in update, though for us, perhaps our gpu has just enough muscle to not be caught on the spike and recover very quickly (GTX770). This means there is just a small glitch or a few milliseconds freeze.
The spike (for us), happens when surfaces &/or meshes are loaded, when panning or moving toward (which might suggest hard drive speed bottleneck)
I wasn't able to hit the screenprint button fast enough to capture the stats at the spike, though I could see allocations increase quite significantly, only to recover very quickly.
post-73-0-67442600-1375060215_thumb.jpg post-73-0-24836700-1375060338_thumb.jpg
Maybe the pipes just get full with crazy amount of data, though, perhaps it is also a combination of a stall loading from the hard drive.
Thoughts..?
Perhaps (after trying Ulf's suggestion), running textures on medium quality to free up some gpu memory and see if the issue persists as an easy test.
N.
hi Ulf and Nat:
   I attached the model hope you could reproduce my problem. I removed all the textures and reduced most of the meshes down to 4.
I still meet the update issue even with those 4 meshes.  The allocations grows fast to almost 1k.
simply change the .node reference meshes path and ref into your level.
 I think it's an mesh optimized issue but I don't know how to optimize it, and it should not be that slow.
Edit:
   I tried engine_analyze, it show world::update_single() use alot of the cpu time
    total     self                 total      self
   ms/frame  ms/frame    calls    ms/call    ms/call  name
    52.308    52.300      2109    52.3085    52.3004  World::update_single()
     1.896     1.605      2109     1.8961     1.6046  RenderRenderer::render_world(const char*,int)
    53.038     0.722      2109    53.0377     0.7219  World::update()
     0.545     0.392      2109     0.5453     0.3915  RenderPost::renderOcclusionAmbient(RenderDeferred*,Texture*&,Texture*&)
     0.521     0.365     99123     0.0111     0.0078  RenderPost::renderPostMaterial2D(Material*,const RenderPostTexture*)
     0.350     0.238      2109     0.3504     0.2383  RenderScene::getIntersection(BoundFrustum&,Occluder&,const Vector<Node*>&)
     0.137     0.129      2109     0.1370     0.1292  WorldSpatial::getIntersection(const BoundFrustum&,const Mat4&,Vector<Node*>&)
     0.121     0.100      2109     0.1213     0.0997  RenderLights::get_light_world_shadow_surfaces(LightWorld*,const Vector<Node*>&)
     0.131     0.079    101232     0.0027     0.0017  RenderRenderer::setShader(int,Shader*)
     0.335     0.072      2109     0.3350     0.0724  RenderPost::renderHDR(Light*,RenderDeferred*,RenderScreen *screen,Texture*,Texture*&,Texture*&,Texture*&)
     0.058     0.055      2109     0.0584     0.0554  WorldSpatial::update_intersection(const WorldBoundFrustum&,Vector<Node*>&)
     0.054     0.054    107559     0.0011     0.0011  RenderState::setMaterial(int,Material*)
     0.134     0.048     32325     0.0087     0.0031  ObjectMesh::render(int,ObjectSurface*)
     0.097     0.048      4218     0.0486     0.0238  RenderPost::render_hdr_average(Texture*,Texture*&)
     0.086     0.037     32325     0.0056     0.0024  RenderRenderer::setObjectSurface(int,ObjectSurface*,Shader*,Material*)
     0.148     0.037      2109     0.1483     0.0373  World::getIntersection(const BoundFrustum&,const Mat4&,Vector<Node*>&)
     0.036     0.036    112467     0.0007     0.0007  RenderRenderer::setShaderMaterialParameters(int)
     0.031     0.031    112467     0.0006     0.0006  RenderRenderer::setShaderParameters()
     0.117     0.022      2109     0.1171     0.0217  RenderPost::renderDOF(RenderDeferred*,RenderScreen*,Texture*&)
     0.021     0.021      2109     0.0206     0.0206  WorldSpatial::getIntersection(const WorldBoundFrustum&,const Vec3&,float,Vector<Object*>&)
     0.018     0.018      7017     0.0053     0.0053  SortSurfaceShader(Vector<ObjectSurface*>&,int)
     0.037     0.017      2109     0.0369     0.0173  RenderLights::render_shadow_world(LightWorld*,Vector<ObjectSurface*>*)
     0.043     0.016      2109     0.0434     0.0165  RenderPost::renderComposite(RenderDeferred*,RenderScreen *screen,Texture*,Texture*,Texture*,Texture*,Texture*,Texture*,Texture*,Texture*,Texture*)
     0.038     0.014      2109     0.0377     0.0139  RenderRenderer::render_visualizer(RenderScene*)
     0.039     0.013      2109     0.0394     0.0132  D3D11RenderPost::renderScattering(Light*,RenderDeferred*)
     0.017     0.013      2109     0.0166     0.0129  RenderRenderer::render_deferred_queries(RenderScene*)
     0.011     0.011      8436     0.0028     0.0028  RenderLights::set_light_world_parameters(LightWorld*)
     0.176     0.011      2109     0.1757     0.0106  RenderLights::renderShadows(RenderScene*,const Vector<Node*>&)
     0.011     0.010      2109     0.0106     0.0105  World::update_intersection(const BoundFrustum&,const Mat4&,Vector<Node*>&)
     0.010     0.010      2109     0.0098     0.0098  RenderManager::update()
     0.009     0.009     15453     0.0012     0.0012  MakeSurfaceChain(Vector<ObjectSurface*>&,int)
     0.008     0.008     34132     0.0005     0.0005  WorldSpatial::getCollision(const WorldBoundBox&,Vector<Object*>&)
     0.045     0.007      2109     0.0454     0.0070  RenderLights::render_light_world_surfaces(LightWorld*,const Vector<ObjectSurface*>&,int)
     0.029     0.007      2109     0.0285     0.0068  RenderRenderer::render_ambient_surfaces(Vector<ObjectSurface*>&,LightWorld*)
     0.029     0.005     99123     0.0006     0.0001  RenderRenderer::setMaterial(int,Material*)
     0.005     0.005      4218     0.0023     0.0023  WorldSpatial::updatePosition(WorldPosition*)
     0.059     0.003      2109     0.0590     0.0035  RenderRenderer::render_deferred_surfaces(Vector<ObjectSurface*>&)
     0.084     0.003      2109     0.0838     0.0034  RenderRenderer::render_scene_opacity(RenderScene*,RenderDeferred*)
     0.674     0.003      2109     0.6737     0.0031  RenderRenderer::render_scene(RenderScene*,RenderDeferred*,RenderScreen *screen,Texture*&,Texture*)
     0.004     0.003      2109     0.0043     0.0030  WorldSpatial::update()
     0.048     0.002      2109     0.0481     0.0024  RenderPost::render_hdr_cross(Material*,Texture*)
     0.003     0.002       895     0.0071     0.0054  Editor::getIntersection(const Vec3&,const Vec3&,const Vector<Node*>&,Vec3&,vec3&,int&)
     0.165     0.002      2109     0.1646     0.0021  RenderLights::render_light_world_shadow(LightWorld*,const Vector<Node*>&)
     0.002     0.002      6327     0.0007     0.0007  SortLight(Vector<Light*>&)
     0.002     0.002     12654     0.0003     0.0003  UpdateSurfaces(Vector<ObjectSurface*>&,const Vec3&)
     0.002     0.002      4908     0.0008     0.0008  RenderLights::setShaderLightParameters(int)
     0.019     0.002      2799     0.0147     0.0012  RenderLights::render_shadow_opacity_surfaces(Light*,Vector<ObjectSurface*>&)
     0.036     0.002      2109     0.0358     0.0016  RenderLights::render_light_receive_surfaces(Light*,Vector<ObjectSurface*>&,int)
     0.001     0.001      2109     0.0013     0.0013  WorldManager::update()
     0.024     0.001      4218     0.0119     0.0006  RenderRenderer::render_wireframe_surfaces(Vector<ObjectSurface*>&)
     0.042     0.001      2109     0.0417     0.0012  RenderRenderer::render_scene_transparent(RenderScene*,RenderDeferred*,int)
     0.001     0.001      8436     0.0003     0.0003  RenderRenderer::render_transparent(RenderScene*,RenderDeferred*,int,int)
     0.001     0.001      2109     0.0009     0.0009  RenderScene::hasVelocity()
     0.001     0.001      2109     0.0009     0.0009  WorldSpatial::add_positions()
     0.001     0.001      2109     0.0009     0.0009  RenderScene::update_intersection()
     0.047     0.001      2109     0.0468     0.0008  RenderLights::renderOpacitySurfaces(RenderScene*,const Vector<ObjectSurface*>&,int group)
     0.001     0.001      2109     0.0008     0.0008  RenderScene::hasAuxiliary()
     0.001     0.001      2109     0.0008     0.0008  RenderRenderer::setShaderMaterialAmbientParameters(int)
     0.001     0.001      2109     0.0007     0.0007  WorldSpatial::getIntersection(const WorldBoundSphere&,Vector<LightWorld*>&)
     0.001     0.001       895     0.0017     0.0017  WorldSpatial::getIntersection(const Vec3&,const Vec3&,Vector<Object*>&)
     0.001     0.001      2109     0.0007     0.0007  RenderLights::render_light_prob_surfaces(const Vector<ObjectSurface*>&,int)
     0.001     0.001      7273     0.0003     0.0002  WorldSpatial::flush()
     0.001     0.001      2109     0.0006     0.0006  Physics::flush()
     0.001     0.001      2109     0.0006     0.0006  RenderRenderer::render_reflections(RenderScene*)
     0.001     0.001      2109     0.0006     0.0006  RenderLights::setShaderMaterialLightParameters(int)
     0.001     0.001      2109     0.0005     0.0005  RenderScene::linearize()
     0.001     0.001      2109     0.0005     0.0005  RenderScene::hasEmission()
     0.000     0.000      2109     0.0005     0.0005  SortSurfaceDistance(Vector<ObjectSurface*>&,const vec3&)
     0.000     0.000      8436     0.0001     0.0001  WorldSpatial::getIntersection(const WorldBoundBox&,int,Vector<Node*>&)
     0.000     0.000      2109     0.0003     0.0003  RenderPost::renderFade()
     0.001     0.000      7273     0.0002     0.0001  PhysicsScene::restoreContacts()
     0.000     0.000      2109     0.0003     0.0003  SoundManager::update()
     0.000     0.000      2109     0.0002     0.0002  RenderRenderer::render_procedurals(const Vector<Material*>&)
     0.000     0.000      2109     0.0002     0.0002  RenderRenderer::render_ambient_object_decals(Vector<ObjectDecal*>&,LightWorld *light)
     0.000     0.000      2109     0.0002     0.0002  RenderRenderer::render_deferred_decal_renders(Vector<DecalRender*>&)
     0.000     0.000      2109     0.0002     0.0002  RenderLights::renderObjectDecals(RenderScene*,const Vector<ObjectDecal*>&)
     0.000     0.000      2109     0.0002     0.0002  RenderRenderer::render_deferred_object_decals(Vector<ObjectDecal*>&)
     0.000     0.000      2109     0.0002     0.0002  RenderRenderer::render_ambient_decal_renders(Vector<DecalRender*>&,LightWorld *light)
     0.000     0.000      2109     0.0001     0.0001  RenderLights::renderDecalRenders(RenderScene*,const Vector<DecalRender*>&)
     0.000     0.000      2109     0.0001     0.0001  RenderRenderer::render_deferred_surfaces(Vector<ObjectSurface*>&,int)
     0.004    -0.002      7273     0.0011    -0.0005  Physics::simulation_multiple(float)
     0.001    -0.002      6327     0.0004    -0.0006  WorldSpatial::getIntersection(const WorldBoundSphere&,int,Vector<Node*>&)
     0.000    -0.007      6327     0.0001    -0.0022  WorldSpatial::getIntersection(const WorldBoundFrustum&,int,Vector<Node*>&)
     0.004    -0.008    152544     0.0001    -0.0001  RenderState::setMaterial(Material*)
     0.086    -0.029      7273     0.0248    -0.0083  WorldSpatial::getCollision(const WorldBoundSphere&,Vector<Object*>&)
     0.019    -0.047      7273     0.0055    -0.0135  World::flush()
     0.123    -0.094      7273     0.0356    -0.0273  PhysicsScene::getIntersection(const BoundSphere&)
     0.001    -0.180      2109     0.0014    -0.1802  PathFind::update()
     0.152    -1.290      2109     0.1523    -1.2898  Physics::update()
thanks
EDIT: update the new meshes file
Yang
ExpTest2.rar
Hi Yang,
you included in the test files: /meshes/Muscular_Infraspinatus.mesh
node calls for:
<mesh>/meshes/Muscular_Interspinales.mesh</mesh>
no update problems with the other 3 meshes.
* edit - or 4th one you included.
hi Nat:
   sorry, i included the wrong file. Just download it again , I already put it back.
   Strange , i still could reproduce it even with 2 meshes. you need very close and even go half though the mesh.
Yang
Hi Yang,
I downloaded again, unfortunately I could not replicate any change in update, no matter how I viewed your meshes (whether 2 or all of them).
Hope you get to the bottom of the problem. Have you got another computer you could test this on?
Cheers,
N.
hi Nat:
    I think I messed up the engine somewhere. Anyway, after I did a clean install, everything looks back to normal.
sorry about that. Will do more test before I post
Yang
