[SOLVED] how can I get camera direction in shader?
I want to write a custom shader for ObjectDynamic, which will need a camera direction. but the shader system has no variable defined as s_camera_dir or s_camera_direction.
so how can I get the camera's direction in shader?
I'm assuming using column 3 of s_imodelview matrix should be the camera direction. But I'm not sure this is right.
Unigine render is camera relative. So in terms of shaders camera direction is 0,0,1 or (0,0,-1). s_imodelview matrix is required only if you need to get world-space camera direction.
Yes, I need the world space camera direction, so column 3 of s_imodelview is the camera direction in world space?
