steve3d Posted September 24, 2013 Posted September 24, 2013 I have a class function which will return a const char*, but I've tried with multiple method to return the pointer from the function, all these will cause the engine crash, seems it's the problem of memory management of script engine. 1 const char *Device::getInfo() { Unigine::String *p = new Unigine::String(device.toString().c_str()); return p->get(); } 2 const char *Device::getInfo() { return device.toString().c_str(); } 3 // create a char info[64] as a member variable of Device class then copy the device.toString().c_str(); to the info array in device's constructor const char *Device::getInfo() { return info; } all this will not work if I use the function as these in script log.message("got device: %s\n", device.getInfo()); And I also tried to change the class function to Unigine::String Device::getInfo() const ; it still won't work. So how can I return a string from a plugin function to use in script?
steve3d Posted September 24, 2013 Author Posted September 24, 2013 I know method 2 definitly won't work, because the device.toString() return's a temp std::string variable and will be deleted after the function returns. but I can not understand why the others won't work . all crash info are same: Program: ...evelop\UnigineSDK_source_2013-08-16_windows\bin\main_x64d.exe File: f:\dd\vctools\crt_bld\self_64_amd64\crt\src\dbgheap.c Line: 1424 Expression: _pFirstBlock == pHead For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts. (Press Retry to debug the application) main_x64d.exe has triggered a breakpoint. The program '[2652] main_x64d.exe' has exited with code 0 (0x0).
frustum Posted September 24, 2013 Posted September 24, 2013 All methods should work. What compiler version do you using?
steve3d Posted September 24, 2013 Author Posted September 24, 2013 i'm using visual studio 2012 with update 3 and debug version of engine.
steve3d Posted September 24, 2013 Author Posted September 24, 2013 OK, this is not a problem, the device sdk are built with vs2010, and I'm using vs2012, this only happens when I use /RTC1 to compile the plugin, when switching to the release version and don't use run time check, everything works fine, except the method 2 won't work.
frustum Posted October 7, 2013 Posted October 7, 2013 Check the Interface plugin source code (source/plugins/Interface/Interface/). We are using all "string to script" variants without any problem.
