lars.saalbach Posted October 15, 2013 Posted October 15, 2013 Good morning, I got a very strange behavior with the attached sample: We have two different classes: - "RootContainer" (Sub: ContainerGroup) - "RootWidget" (Sub: Label) Both of them inherit the function "getParent". In setElementAndValidate(...) we pass an created class and calling: "_parent.getParent()" If the passed object is an instance of "RootContainer" we can call getParent(), if object is an instance of "RootWidget" the interpreter has some troubles: typeof(_parent): GUI::QB::ContainerRoot Name: containergroup typeof(_parent): GUI::QB::ContainerGroup Name: label Machine::do_callucfv(): "GUI::QB::Label 0x7f1e82d83800 (196613:0:0)" is not a suitable user class Stack dump: 0x0000: GUI::QB::Label 0x7f1e82d83800 (196613:0:0) Call stack: 00: 0x00000618 setElementAndValidate() 01: 0x0000066d init() Disassemble: 0x0000063f: callucfv ContainerRoot.getParent 0x00000571 0x00000643: popucx ContainerRoot 0x00000645: popv parent If we change the parameter type from "ContainerGroup _parent" to "void", "Widget" or "int" the interpreter is crashing now at "RootContainer" as well. If we check the class type with "typeof" and cast _parent to the specific class, its working. For me it seems like a bug in the interpreter that causes a wrong detection of the instance type. The expected behavior should be that the instance is correctly detected and code execution continues.Greetings sample.tar.gz
necris Posted October 16, 2013 Posted October 16, 2013 Hello, LarsWe can't cast _parent without specific class declaration."void", "Widget" or "int" types don't have getParent() method.And when you call getParent() you need explicit declaration of it's type: parent = GUI::QB::Label(_parent).getParent(); parent = GUI::QB::ContainerRoot(_parent).getParent(); ... Or you can use is_base_classYou can also use proposed tip from Tips and tricks : "Interface class support and virtual function declaration"
lars.saalbach Posted October 16, 2013 Author Posted October 16, 2013 Hello Necris, i'm gonna check it with the Tip and tricks section :) Thanks so far!
lars.saalbach Posted October 20, 2013 Author Posted October 20, 2013 Update:With multiple inheritance this problem was solved. Thanks for this tip :)Greetings Lars
