[SOLVED] xml save problems
It seems that xml.save() is saving relative to the application path rather than the data path and doesn't respect absolute paths. Why is this so? I almost always want to save stuff relative to the data path I can manually put in the ../data but this breaks when we use the double precision build. What is the best way to deal with this.
There is no difference in Xml::save() internal code with other systems. It should work in same way as File class does. Can you describe the difference more precisely.
Ok I have a piece of code that saves xml file
xml.save(format("%s%s/tracks/flythroughts/%s.track",engine.getDataPath(),dirname(engine.world.getName()),trackname));
note that I have used engine.world.setName() in the world init function to set engine.world.getName() to the full path relative to data.
This generates a file in bin/double_precisision/home/danni/Work/ai3drealtime-5.0/data/Levels/...
a relative path eg
xml.save(format("%s/tracks/flythroughs/%s.track",dirname(engine.world.getName(),trackname);
also generates a file in bin/double_precision/Levels/...
I have solved the problem using
relname(engine.getAppPath(),engine.getDataPath());
but I was pretty sure that in other cases xml.save was behaving quite differently
