Unigine::Widgets::DialogColor paletteColors
Looking into sources I find in "scripts/common/dialogs.h":
string config_name = "color_dialog_palette_default";
/* load dialog setting from config
void load_config() {
    if(engine.config.isExist(config_name)) {
      dialog.setPaletteColors(engine.config.getString(config_name));
It would be nice if we could have the  same functionality in "core/systems/widgets/widget_dialog_color.h", as follows:
// constructor
DialogColor(string str = 0) {
   dialog_color = new WidgetDialogColor(engine.getGui(),str);
   dialog = dialog_color;
      dialog_color.setPaletteColors(engine.config.getString(config_name));
     #ifdef HAS_INTERFACE
       interface = new InterfaceWindow(0,"core/gui/");
       dialog.setCallback(PRESSED,"Unigine::Widgets::Dialog::pressed_callback",this);
       dialog.setPosition(0,0);
        dialog.setMoveable(0);
     #endif
     widget = dialog;
Even better if we can pass the palette as an argument in function dialogColor(string str,vec4 &color,CallbackBase callback = NULL, string palette = "")
Thanks in advance,
      David
