[SOLVED] Shader Blending
Dear Unigine Developers,
Do you think it would be hard to implement shader blending in Unigine?  I know this has been done in Unreal:
They are using a simple texture mask to blend between multiple shaders on a single mesh, instead of using separate material ID's on the mesh (the classic way of doing it).
mesh_layer_base material allows to mix two different materials in according to blending texture.
Would it be possible to drive the blending via a procedural value instead of a texture?
Should be possible by inheriting a material from mesh_layer_base and replace the fragment shader. Then within a copy of the base shader simpl replace the texture lookup with your procedural code for blend weighting
Hi Ken!
By using mesh_layer_base you can mix two basic materials (diffuse + normal), it's actually not shader blending as we're mixing textures instead of shaders. Ulf's right, to implement your blending logic just inherit from mesh_layer_base and replace the fragment shader.
Mesh_layer_base performs two material calculations independently. Mixing texture blends final shading results.
Thanks guys... my evil plan looks very plausible at the moment with all of this information.
It's been a while since I've been using Unigine without mobile in mind, so I'm having some fun.
