danni.coy Posted November 13, 2013 Posted November 13, 2013 I have a node that is added via Node node = load_node([path to node]); making a vector of those objects via forloop (int i=0; max) { markers.append(node_clone(node)); } I want to remove some nodes from the world in that list. for (int i=markers.size()-1; i>=new_max; i--) { markers.remove(i); } does not remove the node from the world. for (int i=markers.size()-1;i>=new_max;i--) { Node n = markers[i]; markers.remove(i); node_delete(n); } or any variation there of gives me the following issue. ExternClass::destructor(): object is not constructed in "P10ObjectMesh" class
danni.coy Posted November 13, 2013 Author Posted November 13, 2013 in answer to my own question for (int i=markers.size()-1;i>=new_max;i--) { Node n = markers[i]; markers.remove(i); node_delete(node_append(n)); } actually works
unclebob Posted November 13, 2013 Posted November 13, 2013 Hey Danni, That's just because cloned node doesn't belong to any script (editor/world/system) so you need to use node_append in order to destroy it properly.
