werner.poetzelberger Posted November 19, 2013 Posted November 19, 2013 Hi, i am using a grass objects which is doing fine. When I add a second world light to the scene, it turns black. Unfortuately this doesnot change if I use a lightmask. I have attached the material parameters as well. Any Ideas about that? Cheers. Werner
werner.poetzelberger Posted November 19, 2013 Author Posted November 19, 2013 Ok, I am playing with the lightmasks. Something is changing ... let me test. Sorry. This was my fault. Everything is fine. I could figure it out and adjust the lightmasks correctly! BUUT in the end it was not the lightmask, but an issue with the blending in the material. Very strange settings, anyway I could figure it out, by setting everything to standard. Cheers Werner
