[SOLVED] Color of pixel when pick.
I have some difficulty for found a color pixel of my object when I pick on it :
I have a plane with diffuse, I want when i pick on it grab the color of the pixel.
My first problem, It's for access to the texture of the material, I try to use getImageTextureImage
Image test = new Image();
test.create2D(128,128,IMAGE_FORMAT_RGB8);
mat.getImageTextureImage(mat.findTexture("diffuse"),test);
I have an error message : GLTexture::getImage(): unknown texture format DXT5
I keep the diffuse image inside my class for use it without pass by material,  I use engine.world.getIntersection who return and ret[4] with the uv coordinates,
I convert for have the pixel of my images, but the color is wrong :
Obstacle impacted ... at 0.032473
Coord UV 0.62822 0.440767 0 0
Coord Pixel 80x56
Color 0 0 0 1
some suggestion ?
Thanks
Tony
PS : It's possible to do similar things (pick color pixel) on ObjectSky ??
Please load an Image from the corresponded file and decompress it from DXT format via Image::decompress() function. After that you can call Image::get2D() function.
Hi Frustum,
Sorry I am not sure to understand, I don't have the image file, I download a bigger image and when i generate the material I use copy for take some part of the image. But I don't keep this image part.
It's for that I was trying to access via getImageTextureImage.
Can you explain me more please ?
Tony
getImageTextureImage() function can't return the DXT compressed format. There is no such function in OpenGL API. This function can only get uncompressed (R/RG/RGB/RGBA) image data from video memory.
