[SOLVED] improvement on the uniginescript error log
hi:
   Since there is no good debugger for the script. so the log is very important to discover bugs.
sometimes the log doesn't say which line. i have to check for a longer time to find it.
example: when you have a wrong “{”“}” brace pair or sometime like the following
"16:13:12 Variable::operator!=(): bad operands string and int"
  which is that i use a string in a wrong place, but it doesn't say which line.
It's already in the feature list, but we can't give any ETA, as it's not the top of the list. Sorry.
  • 3 weeks later...
it's should be easier to debug
21:27:13 ---- Game Framework Plugin ----
21:27:13 Version: 0.01
21:27:13
21:27:13 Parser::check_braces(): some errors with count of '{' and '}' symbols
21:27:13 Parser::preprocessor(): wrong number of braces
21:27:13 Parser::preprocessor(): can't load "memory" file
21:27:13 Interpreter::addExpression(): can't parse expression
21:27:13 Game::LogicModules::compile(): Can't compile logic module
21:27:13 FrameworkEditor::load_logic(): Can't compile a game logic.
21:27:13 FrameworkEditor::load_data(): Can't build the entity tree.
21:27:13 Editor::editor_load(): editor is already loaded
  • 4 weeks later...
