wrong sun direction calculation in core/scripts/time.h
I finally found this problem, in normal situation, from top view of 3dsmax, we often assume this kind of direction
     N(Y)
(-X)W<-->E(X)
    S(-Y)
so this means in unigine, +Y is north, -Y is south, and +X is east, -X is west, in core/scripts/time.h it can calculate the sun direction from a time and latitude/longitude, I have tested my city with time.h and http://www.esrl.noaa.gov/gmd/grad/solcalc/ this calculator, their result of azimuth/altitude are exactly same. but after using the getSunDirection(), the sun always lit from wrong position.
here is a image of azimuth/altitude
from this picture, if azimut = altitude = 0 then the sun direction vector should be (0, 1, 0), then the equation of sun direction vector should be:
normalize(vec3(sin(azimuth) ,cos(azimuth), sin(altitude)))
if I use original code, the sun always rise from south and falls in north. and the sun at 13:00 will be from east.
combined with this post https://developer.unigine.com/forum/topic/239-serious-bug-in-softimage-export-plugin/ , I think it was caused by same problem.
If I'm all wrong about this. then I'm really confused about unigine's coordinate system.
I'm living in Nanjing/China so the constructor of Time should be
Unigine::Time(8.0f, 32.02f, 118.76f );
it's definitely right , you can get this value from http://www.esrl.noaa.gov/gmd/grad/solcalc/
or, you can test it use tomsik's location. 3dsmax's coordinate system is same with unigine's coordinate system.
