[SOLVED] Extending Class Problem
Another quick question. I just don't get why the code below doesn't work:
class ExtendNode : Node
    ObjectMeshSkinned mesh;
    ExtendNode (string nNodeName, vec3 nPos)
        // brabra
int init()
   ExtendNode nNode;= new ExtendNode("something", vec3(0));
   nNode.setPosition(vec3(1));
Basically, it always gives me error upon calling setPosition() function on the extended node class...
Can someone help shine some light on this?
Thx. :-)
Hi, you can't extend external class "Node" on a unigine scripts.
But you can write a user class that allow to code user interface to the Node class.
#include <core/unigine.h>
class ExtendNode {
		Node node;
		ExtendNode(string name,Vec3 pos) {
			// create your node
			node = node_append(engine.world.loadNode("data/test/test.node"));
			node.setName(name);
		// interface
		void setPosition(Vec3 pos) {
			node.setPosition(pos);
		vec3 getPosition() {
			return node.getPosition();
		 * your other methods
ExtendNode node;
int init() {
	node = new ExtendNode("something",Vec3_zero);
	node.setPosition(Vec3_one);
