simulate timeline of keyline system
How to simulate the WidgetHSlider of keyline system by using a special output device like an uart slider? Which means when I change the uart slider's position, timeline slider's position is changing with it at the same time without dragging mouse. How to achieve it? Do I need more information about how widget's callback events are defined with binary version sdk? Thanks!
As far as I understand you would like to use some kind of hardware input device for timeline control, right ? If so, the following general steps would maybe do the trick:
  1. write a c++ plugin for hardware setup/shutdown in Plugin.init()/Plugin.shutdown() and slider value polling in Plugin.update()
  2. expose c++ value query function to UNIGINE script e.g. <pluginname>.getSliderValue()
  3. query current hardware value via <pluginname>.getSliderValue() from within world script update() function each frame
  4. update timeline position based on current hardware slider position via KeyLine::KeyLineManager::setPos() function each frame
There is a useful plugin sample in source\samples\Api\Plugin demonstrating c++ part and UNIGINE script access
Depending on how complex your set up is going to end up I would at least concider using MIDI,OSC or DMX as an intermediatory. The advantages being that your design will work with quite a lot of off the shelf hardware and you can use existing libraries to do most of the work.
Yes,you are quite right. I've done all the steps you have mentioned except for the last one, I've updated timeline position via KeyLine::KeyLineManager::getPos() function each frame. Data from input device is now delivered to keyline system, but got some weird "0" result. My question is how does Gui callback events defined(like Gui::GUI_CHANGED)? As the simulation is when data received from input device just like draggine mouse to change position of timeline slider, i need to know more about define mechanism of Gui callback events(some xml codes: <callback type="changed">KeylineWindow::slider_pos_changed</callback>). Actually I have got some "right" results by commenting "slider.setCallbackEnabled(GUI_CHANGED,1)" in update_slider_pos() function of keyline_window.h file.
I don't understand why you want to use some additional GUI callbacks for timeline control when this should be done via external hardware device and direct calls to KeyLine::KeyLineManager::setPos().
  • 2 weeks later...
The reason why I want to use GUI callbacks is that it seems keyline system use GUI callbacks to trigger the position changing of slider when mouse clicked.
void update_slider_pos() {
slider.setCallbackEnabled(GUI_CHANGED,0);
slider.setValue(int(keyline_manager.getPos()));
slider.setCallbackEnabled(GUI_CHANGED,1);
update_keyline_ui();
And I think I may need some kind of mechanism like when data received differs that slider of timeline changes.
  • 2 weeks later...
Did I go to the wrong direction or is there any more better solution for the above question?
