Xml Memory Leak
I have created xml like
Xml test = new Xml();
after that added few child
for(int i = 0; i < 100; i++)
      test.addChild("test" + i);
saved the xml using
test.save("test");
When i run console command world_memory_usage
it say xml has 'x' mb usage
after that i deleted xml using delete
delete test;
after deletion i checked again world_memory_usage
it showed the same 'x' mb usage
did i forget anything which need to be done before delete xml for clearing memory?
I am NOT 100% sure, but as Unigine internal script garbage collection not always kicks in immediately (e.g. every frame) you shouldn't expect an immedeate drop of allocated pysical memory. Maybe it will be released later or only after exceeding some memory limit.
Thanks for the quick reply, Ulf. Actually it does not deallocate the memory until the exe is shutdown. In fact this issue is creating a memory leak that's crashing the exe within a few minutes.
Ok, then Unigine crew should have a look on issue.
Hi santosh.a,
Thank you for the detailed description! I've made a simple test scene with your code, could you please confirm that Memory, Heap, Allocation counters from profiler are not increasing when you open test_xml world? Please, correct scene if I made a mistake.
Actually, memory allocations starting to grow in debug build when world_memory_usage command is being executed (uncomment line 26 in script). I will ask developers if this is actually bug or not.
xml_test.zip
Hi silent,
Memory and heap allocation counters increase and after deleting they don't decrease.
Thanks
Could you please provide scene with xml which cause engine crash? I can't reproduce memory leak with only XML code. However, world_memory_usage will cause memory increase, if called every update, because it prints a lot of info directly into the console. To avoid memory growth you can call clear command.
