[SOLVED] AppWall GUI Crash
We have an AppWall 3x1 and when we are trying to insert a WidgetSprite in each wall application crashes with the following message:
 engine\render\direct3d11\framework\D3D11Gui.cpp:166: Assertion: 'src >= 0 && src < NUM_BLEND_FUNC && "D3D11Gui::set_blend_func(): bad blend src function"'
You can reproduce this issue creating a new project from Ungine SDK browser with the following settings:
- Launchers:
Console script launchers (.bat) with predefined settings
Renderer: DirectX11
Monitors: Wall 2x1
- Video Output
Monitor wall (AppWall plugin) CHECKED
After this step in the "my_project".cpp file, you have to change the init method to this:
int init() {
    PlayerSpectator camera = new PlayerSpectator();
    camera.setPosition(Vec3(2.0f,0.0f,1.5f));
    camera.setDirection(Vec3(-1.0f,0.0f,-0.5f));
    engine.game.setPlayer(camera);
    forloop(int y = 0; engine.wall.getHeight()) {
        forloop(int x = 0; engine.wall.getWidth()) {
            Gui gui = engine.wall.getGui(x,y);
            WidgetSprite logo = new WidgetSprite(engine.getGui(), "unigine.png");
            gui.addChild(logo,GUI_ALIGN_OVERLAP);
What's wrong?
Thanks in advance,
    David García
Hi David,
Thank you for the detailed description! Could you please provide additional information about this issue:
  • How many monitors are connected to the PC?
  • What OS and Unigine SDK version are you currently using?
  • What is the value of video_fullscreen variable in your launch options?
  • Can you reproduce this issue with only one monitor connected?
  • Can you reproduce this issue after deleting my_project/unigine.cfg file?
Hi Silent,
  • How many monitors are connected to the PC? -> 2
  • What OS and Unigine SDK version are you currently using? -> Windows; UNIGINE_Sim_source_windows_2014-03-25
  • What is the value of video_fullscreen variable in your launch options? -> 0
  • Can you reproduce this issue with only one monitor connected? -> I can reproduce this issue.
  • Can you reproduce this issue after deleting my_project/unigine.cfg file? -> I can´t reproduce
The differences between config files are:
Before delete:
<item name="show_gpu" type="int">1</item>
<item name="video_mode" type="int">13</item>
<item name="video_resizable" type="int">1</item>
After delete:
<item name="video_mode" type="int">-1</item>
<item name="video_resizable" type="int">0</item>
  • 1 month later...
Hi Silent,
I've modified the appWall plugin to solve this problem. If you disable the render_gui method on the startup the application don't crash.
Thanks
  • 2 months later...
