[SOLVED] array quesiton
hi
  Is there any way to assign an array? example
ObjectMeshSkinned meshs[0];
void create_scene(ObjectMeshSkinned newmeshes[])
   meshs.copy(newmeshes);  //work
   meshs=newmeshes;   //doesn't work
ok. i should use .copy
You are right, copy() is preferable way to copy arrays. However, you can also do it manually:
target_array.clear();
forloop(int i = 0; source_array.size()) {
   target_array.append(source_array[i]);
