[SOLVED] C++ only Sample
I'm developing a prototype using the C++ API of Unigine. It would be very helpful to have a sample graphics project included (like the Players or Objects examples) in the evaluation kit that uses only the C++ API and does not depend on UnigineScript at all. Would this be possible?
Hello Trevor,
For now, you can refer to the article on Creating C++ Application: https://developer.unigine.com/en/docs/1.0/cpp_api/application#implement
The code of the application presented in this article can be used as it is.
To handle players and objects, you can use methods of the corresponding classes:
Unigine::Player class: https://developer.unigine.com/en/docs/1.0/cpp_api/reference/api_player_class
Unigine::Object class: https://developer.unigine.com/en/docs/1.0/cpp_api/reference/api_object_class
The other objects (such as ObjectBillboard, ObjectMesh, etc.) are inherited from the Unigine::Object class and also have a specific set of methods.
For example, to set a material for an object surface, you can use the setMaterial() method.
