anthony.liot Posted July 4, 2014 Posted July 4, 2014 Hi,I have a mesh with many surfaces, I want detect which surfaces are visible in the frutrum. What is the best way to do that with script ?I have also the possibility to split the surfaces into many ObjectMeshDynamic. I try to use engine.world.getIntersectionObjects with my projection and model view of my camera. But the function return also some object outside the frustrum. _players[CAM_COLLIDER].setFov(FOV + FOV * (engine.app.getWidth() / engine.app.getHeight())); mat4 projection = _players[CAM_COLLIDER].getProjection(); mat4 modelview = _players[CAM_COLLIDER].getModelview(); engine.world.getIntersectionObjects(projection,modelview,ret); log.message("Visible : %d\n",ret.size()); The log message say 96 visible but I have only 24 mesh front of my camera Any idea ?
alterego Posted July 9, 2014 Posted July 9, 2014 Hello,getProjection() returns the projection matrix with unit (1.0) aspect ratio. int ret[0]; mat4 modelview = mat4(camera.getModelview()) * camera.getOffset(); float aspect = float(engine.app.getWidth()) / float(engine.app.getHeight()); mat4 projection = perspective(camera.getFov(),aspect,camera.getZNear(),camera.getZFar()); engine.world.getIntersectionObjects(projection,modelview,ret); int num_surfaces = 0; Unigine::BoundFrustum bound_frustum = new Unigine::BoundFrustum(projection,modelview); forloop(int i = 0;ret.size()) { Object object = ret[i]; forloop(int j = 0; object.getNumSurfaces()) { if(bound_frustum.insideBox(vec3(object.getBoundMin(j)),vec3(object.getBoundMax(j)),object.getWorldTransform())) { num_surfaces++; } } } engine.message("Visible surfaces: %d\n",num_surfaces); engine.world.getIntersectionObjects() Intersection is performed with bounding box.Do you want to cut overlapped objects?Do you want to find the intersection with the polygons?
