[SOLVED] Volumetric clouds in the helicopter demo
Hi everybody
We are evaluating the helicopter demo scenery for our own products (flight simulators) and we observe that the volumetric clouds are not visible within and above the cloud layer. In the documentation we found the approach to create volumetric boxes for the fog and clouds. With the ready to use texture (volume_base_cloud_density) from the core/textures folder, we get a small little volumetric cloud.
Is there a possibility to combine those two approaches? Such as as long as the eyepoint is below or above the cloud layer, the clouds are created as sky clouds and when the eyepoint is within the clouds the volume box creates the clouds?
Thanks and kind regards
Hi Paul,
If you are talking about our Washington demo, please try to change Downsize paramter of the sky material in this demo to none. This will allow you to fly above the clouds, but with little performace penalty.
Please, check this article about sky and volumetric clouds setup here: https://developer.unigine.com/en/docs/1.0/objects/objects/sky/
Also, you can check our sky samples: <SDK>/data/samples/objects/sky_*
Hi Silent
the downsize parameter does for the moment what we were looking for.
Thanks a lot
  • 3 weeks later...
Hi there
With the downsize param I can change the material to be rendered into a fullsized buffer, but somehow i can't figure out how to save it permanentely. I tried it as well with adding the following line to the environment.mat file. But everytime I restart the scenery, the downsize param changed back to 'greater_scale'.
<material name="sky" parent="sky_base">
    <options downsize="none"/>
    <state name="clouds">0</state>
    <texture name="mask_0">washington/textures/environment/clouds_mask1_d.dds</texture>
    <texture name="mask_1">washington/textures/environment/clouds_mask2_d.dds</texture>
</material>
Thanks in advance
Hi Paul,
Please, try to delete <options downsize="none"/> completely :
</material>
Hi Silent
Then I get the same behaviour as with the option parameter... After starting Unigine, the clouds param 'Downsize' is always on 'greater_scale'.
Thanks
Hi Paul,
Please, take a look at the tracker files (they are located in <Waashington>/data/washinhton/tracks directory).
In the most *.track files you can find following code:
<parameter type="material.downsize" name="sky">
   <key time="0">3</key>
Tracker is setting up Downsize parameter to the value 3 (which equals to greater scale) to sky material. You can replace 3 with 0 to enable Downsize: none option.
Ah, okay! This is it! Thanks a lot!!
