sergey.pozhidaev Posted August 4, 2014 Posted August 4, 2014 hi, i added custom class in one plugin and in another plugin i use this class, in first plugin Unigine script can send class instance by Variable, in second - ("can't convert extern class to class") plugin1.h: class A_class { public: A_class(); void test(); }; plugin1.cpp A_class::A_class() {} A_class::test() {} A_class* ac = NULL; void setAC(Variable v) { ac = VariableToType<A_class*>(Interpreter::get(), v).value; } //--------- UNIGINE export Interpreter::addExternFunction("setAC",MakeExternFunction(&setAC)); //class export ExternClass<A_class> *a = MakeExternClass<A_class>(); a->addConstructor(); a->addFunction("test", &A_class::test); Interpreter::addExternClass("A_class", a); plugin2.cpp #include "plugin1.h" A_class* ac = NULL; void setAC(Variable v) { ac = VariableToType<A_class*>(Interpreter::get(), v).value; } //--------- UNIGINE export Interpreter::addExternFunction("setAC2",MakeExternFunction(&setAC)); in UNIGINE script A_class ac = new A_class(); setAC(ac); //OK setAC2(ac); //Variable::getExternClassObject(): can't convert extern class to class A_class* what i must do to fix it?
unclebob Posted August 18, 2014 Posted August 18, 2014 Hey Sergey, I think it's better to keep all API that's related to some functionality in one place. Also, check loading order of your plugins as it may be the trouble in your case.
