[SOLVED] Callbacks?
I need to implement some callbacks into my scripts. By looking trough the documentation I found the GameEvent and GameCallback classes .. but unfortunately there is no real documentation or an example on how to use them.
As an example what I need:
class MyClass {
  void doSomething() {
    runAllRegisteredCallbacks(myArg);
  void registerCallback(callback) {
    registeredCallbacks.append(callback);
MyClass cls;
cls.registerCallback(myFunction);
How would I do this in Unigine Script?
Cheers,
Daniela
Have you checked <UNIGINE_DIR>/data/core/scripts/callback.h?
For this kind of subscription service I use a map (string : CallbackBase) creating the callback objects using the MakeCallback() and MakeCallbackObject() functions.
//define container
Unigine::CallbackBase p_type_callbacks[]= (:); //registered type callbacks
//register callbacks for different events
p_type_callbacks.append("login",	Unigine::MakeCallbackObject(this, "_processRequestLogIn"));
p_type_callbacks.append("ssid",			Unigine::MakeCallbackObject(this, "_processSSID"));
//invoke callback
string myarg= "an argument for the callback";
if( p_type_callbacks.check(type) ) {
	p_type_callbacks[type].run(my_arg);
