marina.kovalevskaya Posted August 22, 2014 Posted August 22, 2014 Good day When you import fbx in Unigine editor, using the plugin "AUTODESK FBX IMPORT PLUGIN" is a distortion of the mesh vertices. how to solve the problem?
marina.kovalevskaya Posted August 22, 2014 Author Posted August 22, 2014 This is decided by setting the plugin for 3ds Max and exported to format .mesh
silent Posted August 22, 2014 Posted August 22, 2014 Hi Marina, Could you please share with us your original FBX model? Probaly, the reason of such precision issue is model pivot, which located far away from coordinate center (0, 0, 0). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
marina.kovalevskaya Posted August 22, 2014 Author Posted August 22, 2014 Thanks for the quick reply! Yes, pivot away. Most likely your assumption is correct. You still need our original FBX model?
silent Posted August 22, 2014 Posted August 22, 2014 We will need to check this model if precision issue will appear again (after changing pivot to 0,0,0 and reimport FBX). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
marina.kovalevskaya Posted August 22, 2014 Author Posted August 22, 2014 Attempts to shift the pivot were unsuccessful. Note that the mesh is not proportional. Attach the mesh screen Link to zip fbx: https://www.dropbox.com/s/ektkaaw9x62yac2/border_far.7z
silent Posted August 22, 2014 Posted August 22, 2014 Please, enable checkbox Use vertex float in Tools (hotkey T)-> Render settings. By default Z-precision is only half float, so you get vertex deformations in your scene. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
